Printing problems
nicholas.m11
(@nicholas-m11)
Printing problems
The other day, while printing a small building, the printer suddenly messed up and started printing wrong (making a ball of pla scrap in the process). After cleaning up the mess I checked the xyz cal and they appeared fine. And then I got the falling when running the cal print code (see picture). I have adjust the live z to no effect. When trying to print the prusa logo it just fails (doesn't fully seat, lines all over the place, etc....). I clean the bed after every print with over 90% ISO and us a glue stick for prints with a small contact area.
Any help would be appreciated
Napsal : 28/07/2018 4:02 am
nicholas.m11
(@nicholas-m11)
Re: Printing problems
Also, forgot to mention, firmware is up to date
Napsal : 28/07/2018 4:03 am
BillC
(@billc)
From the photo it looks as though there is a layer of glue stick residue all over your bed. Can you try cleaning the bed with dish soap and water. Then use a high grit (400 to 600) to rub down the bed, and finally a good clean with your IPA before trying to print again.
The original symptom when the print messed up and created a ball of loose filament also indicates you may have a partial blockage of the nozzle. Using the LCD settings | move axis to move Z to 120mm then use LCD settings | temperature to heat the nozzle to 260 C and let it sit for three or four minutes to melt out any blockage, then reduce temperature back to normal filament temp and from LCD settings | move axis, move the extruder 10mm to confirm good flow from the nozzle.
Reset temperature to 0, wait for everything to cool down and you should be ready to go.
Bill
Tagaytay City, Philippines
Napsal : 28/07/2018 5:26 am
