First layer calibration with a blank SD card
Hello i have an MK2s sinse many years and yesterday MY SD card suddenly was blank. I have managed to get another SD card to print but I cant seem to be able to calibrate my first layer. I assume that the first layer calibration requires some files to be present on the SD card but i dont seem to be able to find the info online on how to set it up.
Napsal : 31/08/2022 6:24 am
RE: First layer calibration with a blank SD card
There are no system-relevant files on the SD card. First-Layer-Calibration is a firmware feature.
Napsal : 31/08/2022 8:35 am
Hey! For the MK2S, first layer calibration is built into the firmware—no SD card files needed. Just go to the LCD menu: Calibration > First Layer Cal. You should be able to run it directly from there. Hope that helps!
Napsal : 16/04/2025 9:02 pm
