Wanting to print 2 colours on the same base layer
Grev
 Grev
(@grev)
Hi all, what I’m trying to do is print a base layer, then print lettering in one colour, then on the same layer at slightly different location print a shape in a different colour. Is there a way to do this with sequential prints? My current plan is to print the base (~3mm), manually change filament colour, print the lettering (~3mm), change colour again and print the shape (~3mm) What I hope to avoid is frequent colour changes at each layer of lettering and shape.
thanks for any insights
Opublikowany : 20/09/2023 2:24 am
RE: Wanting to print 2 colours on the same base layer
search for "manual Mmu"
Print face down.
Set background colour as filament one
Make letters two layers thick. Then when you print you will get one layer of background, two layers of letter colour and then go back to background to finish  the model
Opublikowany : 20/09/2023 7:29 am
