Thermal Runaway out of the blue with latest Firmware
martin.s38
(@martin-s38)
Dear Mr. Prusa
after upgrading my Prusa 2.5s to latest Firmware the printer starts having the issue "Thermal Runaway" what is quite painful if you are on a print which lasts 8+ hours and then in the last 5-10% of the print you get this bloody error.
Checking cables sensors is all fine, going back to the older Version will eliminate this issue, so I am able to reproduce it.
I would realy recommend that you add an Option to continue printing, or to have an Option available to get a alarming when it happens to check the Printer without breaking the current print. You could also go further if the User is not reacting after 15-30 minutes to the Alarm to shutdown the Printer, but if he approves the Alarm print can continue, the current handling of this error is not user friendly.
I uderstand that it is a saftey functionallity, but this bloddy shutown produces a lot of waste and costs a lot of money, and the handling could be done in a more user friendly way.
Thanks for understanding my frustration
Martin
Publié : 14/01/2022 11:45 am
