[Risolto] Prusa Mini+ switch cable
skweng
(@skweng)
Trying to move the on/off switch for the Mini+ to the front. What cables should I be using for this and where can I get these cables?
Thanks,
Postato : 16/05/2021 2:23 pm
Chicago Keri
(@chicago-keri)
RE: Prusa Mini+ switch cable
Posted by: @skweng
Thanks,
Hi!
Welcome to the MK2.5 / MK2.5s forum.
As the MINI uses an external power supply, the power switch is probably 24V low voltage and therefore relatively safe to handle, however the current will be relatively high so wire diameter and connection integrity is more important.  Probably American Wire Gauge 16  (1.5mm2 ) will be fine for a 24v / 160w system. Part of an old extension cord would probably be ok. The crimp on spade terminals might be easily obtainable at an auto parts store(6.3mm), or might be a special size like 4.75mm or 5.0mm which you could find online at electronics suppliers  Digikey or Mouser.
You might get better response to your question in the MINI forum here: https://forum.prusa3d.com/forum/original-prusa-mini/
¡no entiendo Español!
Nein! Nicht Versteh!
Я немного говорю по-русски но не очень хорошо, и...
I'm not very good at English either! Maybe someday I'll find a language I'm good at?
Postato : 16/05/2021 7:41 pm
skweng
(@skweng)
Thanks
Thanks! Sorry didn't realised this was posted on the MK forum!
Posted by: @chicago-keri
Posted by: @skweng
Thanks,
Hi!
Postato : 15/07/2021 7:55 am
