No "Unload" menu now
Mik
 Mik
(@mik-2)
I just upgraded my faithful old 2.5S and I can't find the menu item to Unload the filament.  Can anyone help this dimwit out please?
Posted : 08/03/2026 2:55 am
christopher.a2
(@christopher-a2)
RE: No "Unload" menu now
Hello fellow legacy user
its in the root of the menu if I'm not mistaken, so not finding it is kind of suspicious,
do you also not see the load filament option?
do you have auto load enabled in the filament sensor settings?
if the autoload is enabled and you cannot see the unload filament option then it might be that the filament sensor is malfunctioning,
check in the support -> sensors -> the filament sensor reading, is it 0 with filament loaded? then its malfunctioning, disable the filament sensor and you will be able to print
this might be related to the upgrade you mentioned, if you upgraded the filament sensor you might need to use a different FW
Posted : 14/03/2026 10:52 pm
Mik
 Mik
(@mik-2)
Thx.  Helpful.  M
Posted : 15/03/2026 7:11 pm
