MK3S+ Hot End on a MK2.5S. Which firmware?
I have a stock MK3S Plus hot end and I want to put it on my MK2.5S. Will I just use the MK3S+ firmware? Or will I need a modified firmware that understands the MK2.5 hardware configuration but ALSO the MK3S extruder?
For example: Bondtech makes a MK3S hot end upgrade for the MK2.5 but they then offer a modified version of the Prusa firmware in order for it to run. Should I just use that firmware?
This topic was modified 4 hours ago by dapug
Posted : 28/10/2024 4:10 am
