M112 Looks like Bed thermistor????
leeroy
(@leeroy)
Greetings,
    My MK3S has been chugging along for years, this is the first problem. I have the little Pi Zero running the show and I can see that the bed temp reporting gets all wacky before the stop. Looks like I will replace the thermistor, can someone tell me the specs needed? I am thinking the problem is not with the heated bed, just the sensor.
Thanks,
Lee.
Questa discussione è stata modificata 3 years fa da leeroy
Postato : 08/04/2023 9:32 pm
Hello
(@hello)
RE: M112 Looks like Bed thermistor????
I ve just ordered zero what plugins are you using with your zero and if you contact prusa through live chat they can tell you
Postato : 10/04/2023 8:19 pm
leeroy
(@leeroy)
Only thing I ever added to the prusaprint Octopi image I installed was Octolapse for time laspe photography with Pi camera. However the zero (Mine is the first version, single core) it struggled a bit to keep up so I abandoned the camera. Nothing other than that. It is likely overdue for an upgrade but it still seems to chug along. I ordered a bed thermistor and also have a Revo upgrade for the hotend I am about to install. I'll post back here if that was the source of the M112.
Thanks,
Lee.
Postato : 10/04/2023 10:12 pm
