Upgrading a MK2.5S+ with EinsyRambo Board?
Jason
(@jason-21)
I currently have an MK2.5 that has been upgraded to a "MK2.5S+" using this guide:
https://help.prusa3d.com/article/upgrading-mk2-s-and-mk2-5-s-to-mk2-5s_200009
So, I have the updated Pinda 2 probe and steel sheet bed, etc.
However, due to recent problems I've been having with heatbed/PSU connector melting issues, I am considering replacing the mainboard.  It looks like a new EinsyRambo is about the same price as a replacement for my current MiniRambo 1.3a.
How feasible is it to upgrade to the EinsyRambo?  From what I've read so far, it seems like I would just need a new 24V PSU, and part cooling fan.  If I did this, would I then be able to run MK3 firmware?  Are there any upgrade guides out there that would might be helpful?  What would be the minimum I would need to just get it functioning with the new board?
Thanks
Publié : 07/05/2023 2:00 am
RE: Upgrading a MK2.5S+ with EinsyRambo Board?
you would need a lot more...
24v heat bed, mk3 Y platform (heat bed mountings are different between 12 volt and 24 volt heatbed), 24 volt heater for the hot end, revised Z brackets to restore the increased Z height.  sort out Y motor direction, the Mk2 frame has the motor on the opposite side of the belt drive compared to the Mk3 frame, so the Y  axis would go backwards
new Y Belt fixture to match the New Y Platform
Publié : 07/05/2023 7:21 am
Jason
(@jason-21)
Hi Joan,
Thanks for the reply.  After some more searching, this is basically what I am looking to do:
https://forum.prusa3d.com/forum/postid/74913/
However, since it does require some firmware tweaks, I'm probably just going to stick with the MiniRambo.
Thank you.
Publié : 07/05/2023 3:16 pm
