Is the MK2.5S -> MK2.5S+ upgrade worth it?
kirpi
(@kirpi)
Are there any really noticable differences in performance with the new extruder design? If yes, what exactly are they?
Opublikowany : 12/05/2022 12:25 pm
RE: Is the MK2.5S -> MK2.5S+ upgrade worth it?
the mk2.5 S+ changes were mostly to make assembly easier...   not a real benefit for you I suspect...
there is a new red filament sensor, and a new pinda which now uses 3 wires instead of the Mk2.5S pinda which uses 4 wires.
the X axis belt tension retainer is less likely to crack the X axis left end printed part...
If you are having problems with your filament sensor or pinda, it may be a worthwhile upgrade, if not keep your money for the next release...
My Printers are still Mk3S.  Which has an equivalent upgrade path, but I see no benefit in changing to the latest release. at this time
Opublikowany : 13/05/2022 12:30 am
kirpi
(@kirpi)
Thanks! Yes, if it's mainly easier assembly, then it isn't worth it for me. I will work with my MK2.5S until maybe a MK4 gets released. 🙂
Opublikowany : 16/05/2022 8:39 am
Lama
 Lama
(@lama)
I'm in the process to upgrade my MK2s to MK2.5s but I'm interest on this new design. I already have the superpinda so I think there is only extruder part that need to be print. Do I need them all or I can reuse some from my mk2.5s upgrade?
Opublikowany : 18/05/2022 10:09 pm
It would be wise to use all of the extruder parts. In one go
Opublikowany : 08/02/2023 6:07 pm
Lama
 Lama
(@lama)
I have use all the extruder parts except the bloc stop that need to be kept. Everything is working since few months, but I still need to swap firmware if I want to calibrate. Still dont know why
Opublikowany : 08/02/2023 7:13 pm
