Problems loading and unloading thread | MK3S Kit
PizzaMan
(@pizzaman)
I just got my kit for the Original Prusa i3 MK3S and when I try to load and unload the thread, the extruder wont stop moving even after the thread is ready. Is there maybe a problem with the sensor or is there something im doing wrong?
Opublikowany : 11/06/2020 1:05 am
jsw
 jsw
(@jsw)
RE: Problems loading and unloading thread | MK3S Kit
It sounds like the filament sensor is misbehaving.
The first thing I would check is to be sure it gives you definite 1 and 0 readouts with and without the filament present.
Opublikowany : 11/06/2020 1:16 am
PizzaMan
(@pizzaman)
@jsw
How do I do that? (Sorry im very new to this)
Opublikowany : 11/06/2020 1:52 am
jsw
 jsw
(@jsw)
This article discusses the filament sensor and how to test it.
https://www.help.prusa3d.com/en/article/ir-filament-sensor-troubleshooting-mk2-5s-mk3s_112231
The 1 or 0 test is maybe 3/4 of the way down the page.
Opublikowany : 11/06/2020 2:11 am
PizzaMan
(@pizzaman)
@jsw
Ok it looks like the sensor is reading correctly but the heat wont go down after it has finished unloading the wire
Opublikowany : 11/06/2020 4:55 am
Graham
(@graham-2)
Hi i had the same, found it was the wires the wrong way round on the board, fix it in seconds
Opublikowany : 12/06/2020 11:34 am
