Nozzle GCode compatibility warning
OzFax
(@ozfax)
Changed nozzle to 0.4mm with adapter.
Sliced model in latest Prusaslicer (2.6.0) using system preset.
Get:
WARNING
The G-code isn't fully compatible
Nozzle diameter doesn't match
I can't find anywhere (else) to change nozzle diameter in Prusaslicer.
Is there something in the XL firmware I've missed altering when I changed the nozzle (that isn't mentioned in the Instructions)?
Publié : 27/08/2023 12:55 am
OzFax
(@ozfax)
RE: Nozzle GCode compatibility warning
Found it!!
XL Settings -> Hardware -> Nozzle
I'll leave a comment in the On-Line Manual under Nozzle Change
Publié : 27/08/2023 1:32 am
1 personnes ont aimé
Erving S. Erving
(@erving-s-erving)
Where exactly do I find this setting?
Thanks
Publié : 07/11/2023 2:39 am
Acht
 Acht
(@acht)
You find the settings on your Prusa XL Printer. Use the dial to access the Settings Menu (Cog Wheel Icon).
Publié : 07/11/2023 9:54 am
Erving S. Erving
(@erving-s-erving)
Many Thanks!
Publié : 22/11/2023 10:42 pm
Sweetblu
(@sweetblu)
The setting doesn't exist n the newest firmware... Absolutely NO options called Nozzle under hardware 🙁
Publié : 11/12/2023 2:02 am
mvikman
(@mvikman)
Multi Tool: Settings -> Tools -> Tool x -> Nozzle Diameter
Single Tool: Hardware -> Nozzle Diameter
Publié : 12/12/2023 1:20 am
