Trying to send gcode from Prusaslicer to Prusalink on XL 5 tool head
Rob
 Rob
(@rob-6)
So I have been putting my XL trough it' s paces the last 2 weeks.  In general all good.  The anti dribble silicone pads were a pain to get right but are now functioning well.  Even printed a complex part out of PLA with PETG supports and other than some blobs to clean up it worked fantastic.
The one issue is I can slice gcode on Pursalicert 2.7.1 and connect to the printer via a web interface on chrome and download/start a print from there.
I followed all the steps to set up the printer as per the instructions to allow prusaslicer to print directly to the printer. I am unable to connect using the user name and password or the API key....
Update.....
When I browse my network for the printer it does not show up. The printers on raspberry Pi do though.....
Is there a setting on the printer I need to change?
What am I doing wrong? I have read so many of the posts on the forums and I just can't figure it out.
XL is updated with the newest firmware.
Postato : 01/01/2024 3:39 pm
Tojik
(@tojik)
Utenti Moderator
RE: Trying to send gcode from Prusaslicer to Prusalink on XL 5 tool head
Hi, the auto discovery feature is unfortunately not implemented ot he 32bit FW (yet?) you will have to fint the printer's IP (settings -> network -> wifi/ethernet) or something like that, going off memmory. Just put that as the address in PrusaSlicer physical printer setup window. Hope this helps
Postato : 02/01/2024 3:11 pm
Rob
 Rob
(@rob-6)
Correct, that was all entered in the printer setup file with the http user name and password.  I get a timed out error.
I’m just confused why I can connect via browser but the slicer won’t connect. It works with raspberry pi….
I’m not sure if there is a setting I’m missing.
Postato : 02/01/2024 3:41 pm
Tojik
(@tojik)
Utenti Moderator
Do you have PrusaLink selected? Or did you accidentally select Prusa Connect? Can you DM me a screenshot of the physical printer setup window? I really do not know why would that not work.
Postato : 02/01/2024 4:45 pm
Rob
 Rob
(@rob-6)
I’ll get that off when I get home from work.
im using Prusa link.
Postato : 02/01/2024 5:21 pm
Rob
 Rob
(@rob-6)
Well, I’m an idiot and I entered the web address wrong, 190.xxx.xxx.xxx rather than 192.xxx.xxx.xxx
shout out to Tojik on seeing that….
Never noticed that detail after trying things dozens of times.
Postato : 03/01/2024 1:27 pm
1 persone hanno apprezzato
