Remove job from print history
joemiro
(@joemiro)
Hello,
Is there a way to remove a prior job from the PrusaConnect print history? I would like to print a surprise gift for another user of the printer but even jobs started from the SD card show up in the web interface.
Opublikowany : 24/03/2023 2:38 pm
Rename the file(s) as something else...
Opublikowany : 24/03/2023 5:32 pm
Tojik
(@tojik)
Member Moderator
Might be nice to add some sort of a hide/blur feature for the name and preview
Opublikowany : 24/03/2023 5:36 pm
alan polubić
alan
 alan
(@alan-2)
RE: Remove job from print history
have tried to rename  cannot be done in connect history
requested feature is better
Opublikowany : 31/07/2023 5:06 pm
Create wonderfulgift.gcode
rename it as boringroutine.gcode
*then* send it to the printer...
History will show boringroutine.gcode and only you will know what it really is.
Opublikowany : 31/07/2023 6:29 pm
Taurruth
(@taurruth)
That is the dumbest thing I read in a while.
There is a miniature of every part that you print.
If I print a dildo everyone will know what I printed no matter how you name the file.
If at least there was a way to get rid of miniature.
The fact that you can not delete your history or parts of your history, might even break EU laws on data privacy.
Opublikowany : 29/11/2023 8:28 pm
The thumbnail is just a comment section; easy enough to delete or replace.
Opublikowany : 30/11/2023 4:34 am
Zappes
(@zappes)
Print from SD, remove the network cable during the print, delete the print from the SD card afterwards?
My models on Printables
Opublikowany : 30/11/2023 8:21 am
Taurruth
(@taurruth)
If it is so easy how do I do it?
How do I delete thumbnail from something I already printed.
I also see that I can download Gcode from history even after the file was deleted from the printer it self.
Posted by: @zappes
Will it work if my printer has USB stick instead of SD card?
Still it would be much easier if one could delete positions from history.
Opublikowany : 30/11/2023 10:56 pm
Zappes
(@zappes)
I am very sorry, my mind skipped the part with "PrusaConnect" when reading the post. 🙁 Never used that, so I don't know what to do about that.
Opublikowany : 01/12/2023 7:50 am
You don't.  You remove the thumbnail from the file *before* printing.  It just needs a little pre-planning.
Opublikowany : 01/12/2023 8:17 am
