Layer heights on Input Shaper for XL
Hammy
(@hammy-2)
Does anyone know why there is no 0.4mm layer height for the o.6mm nozzle on input shaper? The pre input shaper had this setting. Is it just not ready yet or is there a technical reason for it being missing.
Opublikowany : 25/11/2023 8:54 pm
Chimeric
(@chimeric)
Did you add the 0.4 mm nozzle for your XL in the configuration wizard in Prusa Slicer?
Edit: Oh, I see you stated layer height. No idea...
This post was modified 2 years temu by Chimeric
Opublikowany : 26/11/2023 12:51 am
xenon
(@xenon)
RE: Layer heights on Input Shaper for XL
you can use the old non-IS profiles for IS-enabled printers. it will just be a little slower as the speed and acceleration presets are not as high.
Opublikowany : 02/12/2023 9:31 pm
Hammy
(@hammy-2)
Thanks for the reply. I was hoping we would have a 0.4mm with input shaper so that we could print faster for parts that don't need to be high quality.
Opublikowany : 02/12/2023 9:37 pm
ludodg
(@ludodg)
ditto
Posted by: @hammy-2
Opublikowany : 15/01/2024 6:47 pm
xenon
(@xenon)
then just change the layer height and give it a try, it will most likely just work. IS doesnt depend on layer height.
thicker layers mean overhangs become critical earlier so watch out for that.
Opublikowany : 15/01/2024 7:19 pm
