TXT sheet thinner than smooth sheet
evgn
 evgn
(@evgn)
I want to print on the textured sheet but when I did the first layer calibration on the smooth sheet it worked fine at -2mm but since the I can'extured sheet is thinner than the smooth sheet and it wont let me lower than -2mm I can't get it low enough
Respondido : 15/01/2023 7:20 pm
RE: TXT sheet thinner than smooth sheet
The textured (and satin) sheets are 0.4mm thinner than the smooth sheet, so yes, you need to be about 0.400 more negative. If you're close to -2 you need to reposition your PINDA, just move it a bit higher. You may want to print this guide before you do it: https://www.printables.com/model/57192
It's better than credit cards or zip ties with ill-define thickness and should get you into the -1.000 range, which leaves you plenty of wiggle room up and down.
Respondido : 15/01/2023 8:59 pm
