Printing to edge of print
thejoeben
(@thejoeben)
Hello all,
Apologies if this is a common topic - unsure of what to google for this issue. I finally worked through some issues getting started and got a couple successful prints off! I was inspecting my prints and noticed that the filament isn't reaching all the way to the edge and on the top of this whistle I got some strange looking bits in the middle.
How do I make sure the filament makes it all the way to the edges of my prints?
What most likely caused that odd spot in the middle of the whistle?
Opublikowany : 23/01/2024 3:53 pm
Tysonsw
(@tysonsw)
RE: Printing to edge of print
You should look into the Infill/Overlap settings in the Print settings.Print Settings -> Advanced -> Infill/Perimiters overlap (Expert).
I have this usually changed to 20-25% depending on how bad it is.
Printer: Original Prusa Mini+
Nozzles: E3D 0.25, E3D Nozzle X 0.4 , E3D 0.4, Bondtech 0.6 CHL
Printables: Tysonsw
Mastodon: [email protected]
Opublikowany : 30/01/2024 9:05 am
thejoeben
(@thejoeben)
Thank you! I'll give this a shot now.
Opublikowany : 01/02/2024 9:27 pm
thejoeben
(@thejoeben)
Seemed to work! I also live adjusted the Z height (if that's the right term) and both helped a ton. Got one of my best quality prints yet.
Opublikowany : 01/02/2024 10:51 pm
Tysonsw polubić
