Printed model is smaller than designed part
3dPeter
(@3dpeter)
Hi you all, I've designed a router jig to make a MFT table using a pegboard.
The printed model is 1,23mm (X and Y) smaller than intended. For the Z it was intended to be 5 mm high and it measures only 4,8 mm.
The filament is PLA and i used 100% infill for rigidity.
Opublikowany : 25/03/2022 4:54 pm
RE: Printed model is smaller than designed part
Everything is going to be wild guesses without more data. If you upload your project as a 3mf file, you're likely to get better advice. In Prusaslicer, go to File/Save project as, to create the 3mf file. Zip compress it (right click Compress on Mac and Win11, right click Send to/Compress on Win10) to turn it into a .zip file, which you can attach to a post on this forum. The forum software does not accept .3mf files, it has to be a .zip file.
At minimum I'd print a hollowed out calibration cube to calibrate my extrusion multiplier.
Also as an aside, 100% infill is almost never needed. I'd rather add a couple of perimeters and stick with 20% or less infill.
Opublikowany : 25/03/2022 5:38 pm
3dPeter
(@3dpeter)
jig test.3mf
Opublikowany : 25/03/2022 6:57 pm
Couldn't spot anything obviously wrong with the 3mf file.
While the 0.2mm for Z wouldn't surprise me, the XY shrinkage (at about 1%) is higher than I'd expect. As I said before, I'd start by making sure the extrusion multiplier is correct. Assuming the printer is unmodified, I wouldn't think calibrating e-steps was necessary.
Could be thermal contraction. There's a recent quick discussion thread here on the same topic:
https://forum.prusa3d.com/forum/original-prusa-i3-mk3s-mk3-general-discussion-announcements-and-releases/xy-dimensions-issue/
I would also try 4 perimeters, 20% gyroid infill, as the high infill may contribute to contraction.
Opublikowany : 26/03/2022 1:22 am
1 ludzie polubili
3dPeter
(@3dpeter)
Thanks foor looking in to it. meanwhile i've printed the 20mm calibration Cube and measured with my cheap digital calliper it seems to be oké. I will reprint the router plate with 15% infill. Are there certain infill patterns that are recommended?
Opublikowany : 26/03/2022 7:19 pm
Whilst gyroid is an excellent general fill I generally use cubic for distributing stress around practical parts.  Adaptive and support cubic are mostly about top finish.
@fuchsr is right about fill, 100% is almost always a mistake.
Opublikowany : 27/03/2022 3:48 pm
1 ludzie polubili
Take a look at these knowledgebase articles:
https://help.prusa3d.com/en/article/inifill-patterns_177130
https://help.prusa3d.com/en/article/infill_42
Great discussion of strengths and weaknesses of each infill type and impact of infill vs perimeters.
I found gyroid and adaptive cubic to be the best all-around infills.
Opublikowany : 27/03/2022 3:51 pm
1 ludzie polubili
3dPeter
(@3dpeter)
thx, it is now printing with 15% gyroid infill. We will see when the print is finished and cooled down.
Opublikowany : 27/03/2022 5:39 pm
