Print Stops
Binks
(@binks)
Print Stops
Hi all, I start a print and it suddenly stops. The nozzle and bed temps stay the same. And the nozzle sits at the stoping point. I put new files on the usb than it'll print fine. Next day it'll stop again. Any clues?
Postato : 15/11/2022 6:53 pm
mark
 mark
(@mark)
RE: Print Stops
Posted by: @binks
Are there any error messages? What Slicer and Mini Firmware are you using? Older firmware is not compatible with gcode from the latest Slicer, but reports are usually the hot end crashing into the printed object or the bed, not stopping. You might as well update though and try again.
Regards,
Mark
Postato : 15/11/2022 10:35 pm
Clean the usb pins.  Take a look at the usb socket on the control board, are there any signs of cracked solder joints?  Is the socket at all loose on the board?  (Don't force it or it definitely will be.)
Postato : 15/11/2022 11:06 pm
24kJames
(@24kjames)
RE: Print Stops
Have you tried printing from a different, known working USB drive?
You can also try scanning your usb drive for errors. On a Windows PC, find your drive in File Explorer, right click on it, and select Properties. In the Properties window, select the Tools tab, and under “Error checking,” click Check. Windows will scan the drive, and attempt to repair any errors. Once complete, try your print again.
Regards-
Postato : 16/11/2022 2:55 am
mark
 mark
(@mark)
Posted by: @24kjames
Regards-
I had a USB stick go bad. It would crash the Mini with an error. I had to completely reformat the drive before it would work again.
Regards,
Mark
Postato : 16/11/2022 3:20 am
