PETG first layer; the lines do not stickt together
Hen Mob
(@hen-mob)
Hi
Does anyone have any hints or ideas of what I can do to achieve a solid first layer on my satin sheet.
The first layer of my PETG does not create a solid layer.
I'm using the satin sheet.
I have set the Z adjustment to -2, it seems to be the lowest it will go.
I can't use rafts, since it takes too long to remove them afterwards.
Best Answer by FoxRun3D:
If your lines are not together, the most likely explanation is that your nozzle is too high. If your already at -2 you'll have to move your PINDA sensor a bit higher.
The Super PINDA should have about 1.5 mm distance between nozzle and sensor, so that you’re around -1 when your Live Z is correct. That gives you enough wiggle room up and down.
Instructions for adjusting the PINDA are in:
Mini: https://help.prusa3d.com/en/guide/how-to-replace-superpinda-mini-mini_179912
Mk3S: https://help.prusa3d.com/en/guide/how-to-replace-superpinda-mk3s-mk3s_179920
I put this little gadget on Printables to help position the PINDA: https://www.printables.com/model/57192
Works better than zip ties or credit cards, which have less well-defined heights.
Posted : 10/06/2023 6:03 pm
RE: PETG first layer; the lines do not stickt together
Posted : 11/06/2023 9:23 pm
Hen Mob liked
don't forget to reset live Z to 0.00mm after raising your pinda, otherwise you risk scratching your build plate when you restart your printer.
Posted : 12/06/2023 9:56 am
Hen Mob liked
Hen Mob
(@hen-mob)
Thank you both for you help.
The first layer looks good now 🙂
Posted : 13/06/2023 11:58 am
