Non Prusa Filament issues
JoachimVdG
(@joachimvdg)
I'm having issues using filament other than Prusament.
Some prints are fine, but then all of the sudden there's no filament being extruded. The nozzle and hotend are not clogged so I believe the extruder can not grip the filament enough.
Prusament has a texture which seems to improve extruder grip.
Anyone else having issues and maybe a workaround for this?
I have glow in the dark PLA that works ok for smaller prints, but when I go above 3-4 layers the issue starts. Black PLA seemed to work ok up until after a few prints.
No issues whatsoever with Prusament.
This topic was modified 5 years ago by JoachimVdG
Posted : 24/05/2020 10:32 am
RE: Non Prusa Filament issues
Most 3rd party filaments I've used are a bit less than 1.75mm diameter. I have my extruder tension screws set tight enough to grip these and have no issues. Do you hear the extruder skipping during the print when this happens?
Posted : 24/05/2020 2:58 pm
JoachimVdG
(@joachimvdg)
@bobstro
I don't really hear any extra noises when the extrusion stops.
How far in do you tighten the screw? Is there a 'sweet spot' when the filament is in?
This post was modified 5 years ago by JoachimVdG
Posted : 24/05/2020 4:23 pm
Posted by: @joachim-vdgoten
[...] How far in do you tighten the screw? Is there a 'sweet spot' when the filament is in?
I don't have a Mini, but on my 2 printers, I look for extruder teeth marks when I unload the filament. If the teeth marks are so deep as to deform the filament, I can loosen the screw tension. If there are worn areas where the teeth are slipping, or very faint marks, I can tighten it a bit more.
Posted : 24/05/2020 6:32 pm
JoachimVdG
(@joachimvdg)
I've noticed that the issue is mainly located at the large pinion in the extruder.
It seems to jam more often than not. After a few prints I need to dissasemble the unit and remove the large pinion from the bearing. It's really stuck in there so I have to seriously pull.
I've made sure the screws are not to tight on the housing. So I'm not sure what else could cause this.
Any other ideas?
Posted : 26/05/2020 5:25 pm
JoachimVdG
(@joachimvdg)
+ the extruder idler is not doing what it should. The screw is not sitting flush with the plastic and when I loosen it the door on the other side comes loose.
I have a feeling something is not right
Posted : 26/05/2020 5:50 pm
