Need Help with Stringing
bjohns029
(@bjohns029)
Hi all!
I am trying to print some hooks for my pegboard in my garage to store some of my Ryobi tools, but I am getting significant stringing. Can anyone help me dial in the settings. My current settings are also attached. Thanks!
Respondido : 18/05/2022 2:55 pm
Chris Laudermilk
(@chris-laudermilk)
RE: Need Help with Stringing
Your retraction is 3.5mm, drop that to 2mm to start.
Mini+ (kit) - Revo Micro | Antler Cooling | WiFi (4.4.0RC1)
Respondido : 18/05/2022 3:02 pm
1 les gusta
bjohns029
(@bjohns029)
Posted by: @chris-laudermilk
Thank you for the reply, will try this on my next print of the same pieces and report back results.
Respondido : 18/05/2022 3:14 pm
mark
 mark
(@mark)
What kind of filament? Drying the filament first always improves things, especially for PETG and ASA. I'd suggest that first, then you can try endless setting change / repeat print cycles.
Regards,
Mark
Respondido : 18/05/2022 4:57 pm
bjohns029
(@bjohns029)
Posted by: @mark-3
Regards,
Mark
Oh, I forgot to mention that! Hatchbox PLA. It is in a filament dryer. I am running the second print now with the retraction setting above changed.
Respondido : 18/05/2022 5:49 pm
bjohns029
(@bjohns029)
This is after lowering retraction to 2 mm. Should I change it more? Change temperature? I think it looks better!
Respondido : 18/05/2022 6:05 pm
bjohns029
(@bjohns029)
Posted by: @bjohns029
Posted by: @mark-3
Regards,
Mark
Actually, this is Matter Hackers Build PLA.
Respondido : 18/05/2022 6:13 pm
mark
 mark
(@mark)
Posted by: @mark-3
Regards,
Mark
What kind of dryer? That looks awful for PLA. Typical PETG looks better for me. You need a heated dryer. A box with desiccant packs won't pull moisture out that is already there.
Is the temperature set correctly for PLA? You could also try checking Avoid crossing perimeters.
Regards,
Mark
Respondido : 18/05/2022 6:21 pm
bjohns029
(@bjohns029)
Posted by: @mark-3
Posted by: @mark-3
Regards,
Mark
Regards,
Mark
It is a Sunlu heated dryer from Amazon. I am going to do start doing test prints with a smaller print to try and get some better settings (calibration prints). The temps were for 215 C first layer and 210 C all other layers.
Respondido : 18/05/2022 6:35 pm
Chris Laudermilk
(@chris-laudermilk)
That's still a lot of stringing for PLA. I use Hatchbox and some MatterHackers PLA and don't see that kind of stringing. Those temps are what I usually print at, sometimes bump to 220. You could try dropping retraction more; SuperSlicer has some nice calibrations built in if you use that slicer.
Respondido : 19/05/2022 1:43 pm
