First layer speed
raymate
(@raymate)
First layer speed
Trying to slow down the first layer, my print is at 0.20 Quality setting.
My print has some letters on the bottom like benchy does but as its trying to draw them they don't stick. My first layer calibration is perfect. And Im having no print issues with object that have not bottom detail
It seems as it moves to each letter the moving is too fast. If I do live adjust and set print speed to 50 it works but I want that kind of speed on my first player setting, I don't want to be adjusting live on each print.
Prusa Mini+ (Ordered Dec 19,2020 - Arrived Feb 21,2021) stated clicking Mar 2nd / MP Select Mini V2
Veröffentlicht : 23/02/2021 3:50 pm
RE: First layer speed
Print Settings > Speed > First layer speed
Veröffentlicht : 23/02/2021 5:37 pm
raymate
(@raymate)
Posted by: @diem
I can see that, but what does
Print Settings > Speed > Travel
Print Settings > Speed > First Layer Acceleration
Surely they will impact the results
Veröffentlicht : 24/02/2021 1:00 pm
Turning the front knob is the same as issuing a M220 gcode. It adjusts speeds for all axes (including E) to the specified percentage of whatever the gcode uses. It does not, to the best of my knowledge, adjust acceleration.
Travel speeds shouldn't make much difference, but you can reduce that if you like.
Veröffentlicht : 24/02/2021 1:31 pm
Worth noting that there are acceleration rates for different move types. There's not a gcode command that I'm aware of to adjust all acceleration rates at once akin to M220.
Veröffentlicht : 24/02/2021 1:36 pm
raymate
(@raymate)
@bobstro
Thank you for your answer
Veröffentlicht : 24/02/2021 1:46 pm
