Features on one side of the wall appear as artifacts on the other side
stag
 stag
(@stag)
Hey People,
I've designed and printed a modular bathroom shelving on the Mini. To save some time I switched for a 0.6 mm noozle. However, the print quality is subpar. Features on one side of the wall appear as artifacts on the other side. We are talking about 1.3 mm thick (2 perimeters) walls, yet I want to get rid of the artifacts. One side of the walls are supposed to be flat without any pattern on it. Please see attached photos and find the .stl .3mf file attached. What can I do? I would appreciate your help.
Bathroom shelving
Veröffentlicht : 15/11/2020 2:26 pm
stag
 stag
(@stag)
RE: Features on one side of the wall appear as artifacts on the other side
Update: Printing the external perimeters first helps a bit. The front face looks much better, but the back is still ugly.
Veröffentlicht : 23/11/2020 8:13 am
morp
 morp
(@morp)
I have the same problem (and a slew of others) with the stock .4mm nozzle:
Let me know if you figure out a solution.  Not sure if it's an issue with my printer or in the slicer settings.  But I've printed these models on other printers with no issues at all.
Diese r Beitrag wurde geändert Vor 5 years von morp
Veröffentlicht : 29/11/2020 9:28 pm
@stag
Have you tried adding one or two more perimeters?
@tex
How old is your nozzle - or have you been printing abrasive filaments?
Veröffentlicht : 30/11/2020 2:12 am
morp
 morp
(@morp)
Posted by: @diem
@tex
Whole printer is brand new, including the nozzle.  Haven't run anything other than PLA/petg/asa through it.  This is how it printed right out of the box.
Veröffentlicht : 30/11/2020 2:41 am
stag
 stag
(@stag)
@diem
Well, I haven't tried, the idea is using as small amount of filament as possible, and with 2 perimeters the structure is already pretty solid, so if possible I'd like to avoid that.
Veröffentlicht : 30/11/2020 4:17 am
TeachThePrints
(@teachtheprints)
That's not something you can avoid, unless you add more perimenters. Smaller nozzle and more perimeters, to keep the overall filament usage the same, should work, too.
Prusa Mini FW6.2.4
Veröffentlicht : 30/11/2020 7:42 am
@tex
Uneven extrusion and stringing to that degree has me stumped, I've only seen similar with a worn nozzle.  I can only suggest you go to default settings and check with a known file.
I presume you printed some of the Prusa provided gcodes - did they come out OK?
Sorry not to be of more help. Cheerio,
Veröffentlicht : 30/11/2020 9:52 am
morp
 morp
(@morp)
Posted by: @diem
Tell me about it.  I've reached out to support but am still waiting to hear back.
Here are some prints using the benchy gcode that came on the usb stick:
The middle one is brand new Prusament and looks the best, but I still feel like my printer is underperforming.
I don't mean to derail this thread though.   🙂
Diese r Beitrag wurde geändert Vor 5 years 2 mal von morp
Veröffentlicht : 30/11/2020 10:12 pm
Gordon W
(@gordon-w)
@tex
Use the web chat on the e-shop page, you'll get a quicker response.
Veröffentlicht : 01/12/2020 11:16 am
