Crazy external lines - Images
Steverd
(@steverd)
I started to get these lines on the external surfaces on one of my Mini's (I have 6)
What normally causes this? I am thinking I need to do a Z adjust (Maybe raise it a little?
Thank you for ANY Help
The FILE - CUBE
Opublikowany : 13/12/2021 6:45 pm
Chris Laudermilk
(@chris-laudermilk)
RE: Crazy external lines - Images
Looks like same issue as in this thread: https://forum.prusa3d.com/forum/assembly-and-first-prints-troubleshooting/surface-problem-not-smooth/#post-545182
Mini+ (kit) - Revo Micro | Antler Cooling | WiFi (4.4.0RC1)
Opublikowany : 13/12/2021 6:51 pm
1 ludzie polubili
Steverd
(@steverd)
I also forgot to mention that this is eSun Silk green PLA
Opublikowany : 13/12/2021 8:28 pm
Has nothing to do with live z. Live z only affects the first layer.  Check out that article linked to by cwbullet in the thread mentioned by Chris.
Opublikowany : 13/12/2021 11:42 pm
1 ludzie polubili
Steverd
(@steverd)
I sent this photo to PRUSA Support and here is their offical reply: Please make sure that the extruder idler screw tension is set correctly exactly as mentioned at https://help.prusa3d.com/.../idler-screw-tension_177367/
SO I Have a spare Bondtech Extruder here, Maybe I should install on this Mini?
Thoughts?
Thank you
Opublikowany : 17/12/2021 3:17 am
Both my Minis have Bondtech extruders. Never had to adjust the idler again, never had a clog. So I definitely recommend it. Having said that, I have a hard time seeing the idler as the culprit here.
Opublikowany : 17/12/2021 5:44 am
1 ludzie polubili
Steverd
(@steverd)
I thought the same thing as you about the Idler, but I will install the Bondtech tonight and print a wobble cube.
Thank you
Posted by: @fuchsr
Opublikowany : 18/12/2021 12:13 am
StinkyPete
(@stinkypete)
I saw something similar with my Mini (Bondtech Exrruder and Heatbreak) when trying a new PLA.   I ran a Temperature Tower, and found that the problem went away with a higher nozzle temperature, so I am now running 235 degrees with this particular PLA and am getting VERY good prints.  The high temperature worried me at first, but after some months using that setting I have had no issues and prints remain excellent.
Opublikowany : 26/12/2021 8:46 pm
1 ludzie polubili
Steverd
(@steverd)
Great tip - I will do this if the problem returns! Thank you
Posted by: @stinkypete
Opublikowany : 26/12/2021 9:39 pm
sandysasmita
(@sandysasmita)
Have you tried to use another filament? Or have you try to drying your filament? I have this problem before, and the only solution is dried my filament. I live in moist environment, its about 75% humidity, so if let the filament in the open air, a few days later the print results is terible. So i have to dried the filament or i use filament dryer while printing. Here is sample image similar to yours. The left side is moist filament, after drying my filament, the layer lines going to disappear.
Opublikowany : 28/12/2021 5:23 pm
1 ludzie polubili
