ASA Nasty overhang issues
dhano6
(@dhano6)
Hello,
I am trying to print this with Prusament ASA its 45 degree overhang.. Cooling for bridges was set to 50%. What can I do to make it better?
Napsal : 15/02/2021 8:02 am
RE: ASA Nasty overhang issues
What happens when you increase cooling?
Napsal : 15/02/2021 2:22 pm
dhano6
(@dhano6)
@cwbullet
this was printed with 50% fan I tried also with 0 fan, looks same... 🙁
Napsal : 16/02/2021 12:47 pm
mark
 mark
(@mark)
I have never had good luck with overhangs on ASA. A draft shield (full height skirt) does help. When it prints in the air, it warps and the next layer does not meet it correctly. I usually cut the part into pieces with a flat underside and glue them together with Acetone. It does not look like you can do this with this part.
The tops and sides of ASA parts come out really nice, but the bottoms have to be flat on the bed to look nice.
Regards,
Mark
Napsal : 18/02/2021 4:43 am
dhano6
(@dhano6)
Hi Guys,
I have resolved it finally 🙂 So I discovered a feature in PrusaSlicer where you can see fan speed on each layer and here I discovered that my print is always printed with 0 fan even though my setting was e.g. min 20 max 50 fan speed, the root cause was checkmark "Keep fan always on" it was unchecked when I checked it, it got printed nicely 🙂
Napsal : 18/02/2021 8:27 am
