Z position tops out after print or parking location
Atomic-Kid
(@atomic-kid)
New to the MINI+ and just started printing some taller models. I've noticed that the print head attempts to park after a print is completed much higher than the z-axis can accommodate. I assumed there was a sensor at the top end of the z-axis that would cause the motor to stop, but the grinding that I just heard pretty much negates that possibility.
I manually lowered the head a little bit through the screen. I then did a filament change before the next print. The first step it runs is to "park" the print head, and it does so by moving the z-axis up. It topped out again, grinding the motor for a few seconds and then finally stopped.
This doesn't seem like normal behavior, hoping someone has some insight.
One note, the printer does successfully re-calibrate prior to the print as it moves to the bed, and all my prints have been fantastic!
Thanks
Stephen
Napsal : 20/07/2022 6:44 pm
RE: Z position tops out after print or parking location
This *is* normal behavior. The printer has no direct information where the print head is in space as you may have moved it manually. So it moves the Z-axis up, to be safe. When it hits the top, that stuttering behavior is normal and expected, no reason to be concerned.
Napsal : 20/07/2022 6:53 pm
Atomic-Kid
(@atomic-kid)
Great, thank you for the response. At least that's some peace of mind that it's not going to ruin the printer.
Napsal : 20/07/2022 7:09 pm
