Z-Axis is squeaking at the lower end - what can i use to lubricate it?
Mike Jeffries
(@mike-jeffries)
Shortly after I got the prusa mini earlier this year, I noticed the Z-Axis squeaks towards the bottom (closer to the bed). I only notice the squeaking when the Z-Axis is all the way up and it has to come back down toward the first layer (when it moves quickly to start a new print)... But while it's printing it moves up the Z-axis slowly, so i won't notice the sound
Is there anything I can use to lubricate the z-axis like WD-40 or anything similar?
If so, where do I use the lubricant? (on the metal shaft of the z-axis, on the bearing, etc)?
Veröffentlicht : 18/10/2020 1:16 pm
Gordon W
(@gordon-w)
RE: Z-Axis is squeaking at the lower end - what can i use to lubricate it?
See https://help.prusa3d.com/en/article/regular-maintenance-mini_133222#bearings-maintenance Don't use WD-40. You should have got some lubricant in the spares bag with the printer.
Veröffentlicht : 18/10/2020 2:29 pm
Mike Jeffries
(@mike-jeffries)
@gordon-w
Thank you - i just pulled out the spare kit bag and it was in there! Never paid attention to it until now. Thanks again!
Veröffentlicht : 18/10/2020 2:49 pm
Posted by: @michaelroitman
I would rather not recommend WD40. Use a PTFE containing lubricant instead. Alternatively you could change the trapezoid nut (available as spare part from Prusa).
Veröffentlicht : 18/10/2020 2:51 pm
Anthony
(@anthony-5)
Did lubing solve your issue? I've been having this issue since May and still can't resolve it. I've tried resetting the rod to center it and lubing and still no resolution.
Veröffentlicht : 23/10/2020 6:19 pm
remington
(@remington)
i solved this in a really lowbrow way, lightly cable tying around the two support rods, this cable tie moves and up and down the rods as the print progresses and it immediately solved all the noise. its really really not on tight in the slightest, its appling almost no pressure whatso ever to the leadscrew
Veröffentlicht : 10/11/2020 2:42 pm
@karl-herbert
REcently I believe Prusa include a spare PON nut, in the spares bag
Joan
Veröffentlicht : 11/11/2020 1:59 am
@paulnoble
Necessity is the mother of invention - very good 👍
Veröffentlicht : 11/11/2020 2:56 am
Mr.Shaky
(@mr-shaky)
I had the same squeak in the same spot.  To return to normal operation, I wiped off the slides (including the accumulated gunk marking the extremes of travel,) moved Z to the top and put the very slightest dab of the included lubricant on the slides & screw (roughly above where the squeak was happening.)  I also wiped off X & Y, moved them closest to their respective motors, putting a dab of lube near the center of the slides.
Prusa MINI w/Bondtech IFS extruder, Slice Copperhead groovemount, bed-leveling mod, rerouted heatbed wires, Z brace, MINI Enclosure with relocated displayLDO Voron v2.4 rev 2 C 350…
Veröffentlicht : 16/11/2020 7:38 pm
Poikilos
(@poikilos)
Thanks, that solved the Z-axis low-ish pitch squeal for me, but I only did the lead screw since I could see grease on the edges of the bearings already (Also, I could feel vibration if I held the leadscrew while it made the sound).
Now what about a thinner lubricant for the X & Y? Some people say to use a lubricant designed for faster motion such as PTFE dry lube (to prevent collecting debris) or sewing machine oil on other 3D printers with linear rods.
Diese r Beitrag wurde geändert Vor 6 months 5 mal von Poikilos
Veröffentlicht : 06/11/2025 8:12 pm
