unable to connect from browser to my prusa mini+
DenisC77
(@denisc77)
Hi All,
i have attached my mini+ to my lan using a dhcp address but if I'm unable to connect via browser (page timeout)... I tried also to set a static ip, but without result. I've tested the network cable and it's ok, and iNet network scanner discover the printer with the correct Mac address (I'm on Mac)... what could be the problem?
thanx in advance
Publié : 07/07/2022 8:03 pm
RE: unable to connect from browser to my prusa mini+
As far as I know, the Mini can only be accessed via a graphical user interface. Data can be transferred either via a print server or USB stick.
https://help.prusa3d.com/article/prusa-connect-local-mini_133279
wbr,
Karl
Publié : 07/07/2022 9:07 pm
mark
 mark
(@mark)
Try different browsers and computers. I've found it to be hit and miss, works fine on some setups, not on others, times out as you described. DHCP works fine.
Regards,
Mark
Publié : 08/07/2022 3:58 am
DenisC77
(@denisc77)
@karl-herbert: In the page you linked says it can be accessed over local network via web interface, then with a browser right?
@mark-3: I'll try different computer/browser... I just hope it don't need a windows pc 🙂
thanks
Publié : 08/07/2022 6:44 am
