Supports not created as intended
Basic
(@basic)
Dear all,
I'm recently struggling with the supports of a part... seems like my paint-on supports getting ignored rigorously. Dunno why?
Zipped file attached
Attachment removed
Respondido : 26/07/2021 9:08 am
The usual
This question has been asked—and answered—a million times before:
Turn off Don't support bridges in Print Settings/Support materials. You have to be in advanced mode to do so.
Wish PrusaSlicer made this more obvious or turn Don't support bridges off by default.
Respondido : 26/07/2021 10:56 am
Basic
(@basic)
RE: Tried...
Thanks, fuchsr!
I did, but it's still faulty...
dav
Respondido : 26/07/2021 1:14 pm
Huh?
Okay, that is weird... Here's a screenshot from my system. I unzipped your file, opened the 3mf file, and turned Don't support bridges off:
Supports galore.
I then tried it on my Windows system. Same thing. Just opened the 3mf, turned off Don't support bridges, and got this:
Still better than what you're seeing, but now I'm getting a couple of unsupported regions...
No idea why, this may be a genuine bug.
And just to anticipate one possible response: My Mac and Windows system are using the SAME settings folder, (sitting on Onedrive, symlinked on the Mac), so different settings (outside of what's coming from the 3mf file) are unlikely.
I'm genuinely puzzled.
Respondido : 26/07/2021 9:53 pm
What are you trying to fix?
What are you trying to correct? It looks like you want to increase the distance between the supports and walls -- presumably to ease support removal -- but you've got the contact Z distance set to 0 which will make for non-removable supports. Increase that to 0.25mm if that's the case.
Respondido : 27/07/2021 2:00 am
