Raising the Bed Height - Z Adjust does not go any lower
Resz
 Resz
(@resz)
Whenever I have sticking issues I Live Adjust the Z axis to get a closer/smoother first layer.
However I'm now up to -2.000 on the Z adjust and it does not go any further than that. Even at that level I'm not getting the the first layer I need.
Is there a way to physically increase the bed height or any other method that will help with this issue? Thanks in advance.
Best Answer by mark:
You have to adjust the sensor:
https://help.prusa3d.com/en/guide/height-adjustment-of-m-i-n-d-a-superpinda-sensor-mini-_154547/
Prusa has a big set of instructions on that site for whatever problems you may have.
Regards,
Mark
Napsal : 11/12/2021 6:08 pm
mark
 mark
(@mark)
RE: Raising the Bed Height - Z Adjust does not go any lower
Regards,
Mark
Napsal : 11/12/2021 6:42 pm
1 lidem se líbí
What Mark said. Plus, I created this little gadget to help adjust the PINDA sensor: https://www.prusaprinters.org/prints/57192.
Works better than zip ties or credit cards, which have less well-defined heights.
Napsal : 11/12/2021 8:18 pm
1 lidem se líbí
Resz
 Resz
(@resz)
Thank you. Super easy. Thanks a lot for that
Napsal : 11/12/2021 8:53 pm
Resz
 Resz
(@resz)
Thanks again guys. I'm at a much more manageable height now.
Napsal : 12/12/2021 3:58 pm
