Prusa mini upgrade
HarcosDesign
(@harcosdesign)
Prusa mini upgrade
I'd like to attempt printing technical materials like PC and nylon on my Prusa mini; i'd like to avoid swapping the whole extruder.
Could the bondtech heatbreak be enough? I could also make a custom allmetal heatbreak using my lathe... any suggestions?
Napsal : 14/02/2021 6:54 pm
3D_Scenography
(@3d_scenography)
RE: Prusa mini upgrade
Mini may be able to print those materials without upgrades, albeit I'm not entirely sure.It can reach 280 degrees according to the e-shop and it may already have an all-metal extruder (PTFE tube doesn't reach the nozzle but I can be wrong).
Mine printed TPU without problems, but that's slightly different.
Napsal : 15/02/2021 9:18 am
@3d_scenography
What temperatures do you need to print the filament you are choosing?  The problem is unlikely to be the heartbreak with that material.  I have a standard heartbreak and I print PC Blend.
Napsal : 15/02/2021 11:39 am
