Prusa Mini+ poor print quality
While using the included PLA filament everything went all right but after switching to PETG (official Prusament) I've had a plethora of issues. After tightening the hotend and lifting it I still get this kind spills and it also causes poor print quality. Any ideas?
RE: Prusa Mini+ poor print quality
That orange blob is filament, that came out of the upside of the heatblock? If so, you do not have the nozzle tightened against the heatbreak correctly.
https://help.prusa3d.com/en/article/changing-replacing-the-nozzle-mini_134235
the filament leakage on top of heatblock clearly says that the hotend is wrongly assembled. it turned out on petg because the higher temperature requires a better assembly.
Search on prusa site or youtube for visual instructions on correct way to assembly it. It will be difficult at the beginning but once mastered your prints will be perfect.
@z073
I'have tightened it twice. The leaks haven't stopped.
@serj
consider disassembly the whole hotend and using an M6 screw to clean the thread inside the heatblock.
when nozzle is tight You must have a gap between nozzle and heatblock, at least 0.5mm.
untight the nozzle at high temperature then let it cool down
gently tight by hand while cool then heat it up to 280°C, then gently tight it a little bit.
@serj
I suspect you have debree preventing the fullign tightening. Disassemble cna clean like Turro said above.
@serj
Dissassemble and clean.
