Prusa Mini - PID Tuning?
Ahand59
(@ahand59)
I've been looking for a while and am of the belief the Mini does not support PID tuning that can be saved to the EEPROM. I have checked the Calibration selection on the printer and nothing says PID. There is one selection that seems to support a test to make sure it's working, but nothing about PID tuning. Is this another of those things that has been locked out, due to concern about someone breaking the printer by using your own Marlin settings?
Publié : 26/01/2021 5:12 am
Turro75
(@turro75)
RE: Prusa Mini - PID Tuning?
simply add the M301 command with right values in the start gcode within the slicer or octoprint.
no way for the bed, autotune is enabled only for hotend
Publié : 26/01/2021 9:47 pm
Rick
 Rick
(@rick-2)
This post is very high in Google's results, so here is all the info I needed to PID-tune my Mini. Run this stuff from Pronterface, record the results, and add the gcode at the top of Printer Settings->Start G-code. I have a few mods, so my PIDs are way off Prusa's, and may be worse than the default for your printer!
-Extruder-
M301; view current values
M303 E0 S230 C10; 10 cycles at 230C
M301 P17 I1.5 D47.5; my measured PIDs!!!
 -Bed-
M304; view current values
M303 E-2 S70 C10; 10 cycles at 70C
M304 P44 I3.6 D360; my measured PIDs!!!
Publié : 04/12/2021 9:39 am
3 personnes ont aimé
ViM
 ViM
(@vim)
Membre
I tried to run a PID tune on my Mini+, via pronterface, but I don't understand why it does not work
M301 works fine, and report the current setting
I can drive the printer from my PC, set temps, extrude ...etc
but M303 command is reported as "unknowm"
Every webpage about this seams to be using the same code (sometimes temp or cycle differs, but allways with M303)
>>> M301
SENDING:M301
echo: p:7.00 i:0.50 d:45.00 c:0.01
>>> M303 E0 S230 C10
SENDING:M303 E0 S230 C10
echo:Unknown command: "M303 E0 S230 C10"
Can someone please help me understand why?
I was planning a Hotend upgrade, but it seams a bad idea if I'm not able to get a new PID value in my Startup Gcode 😥
Happy owner of a Prusa Mini+ (with Bontech extruder and heatbreak);)
Publié : 23/09/2023 3:22 pm
1 personnes ont aimé
alex3D
(@alex3d-2)
Membre
I am experiencing the same issue
Publié : 09/11/2023 2:32 am
Mr Slingman
(@mr-slingman)
What kind of cable are you using to connect from your computer to the Mini?
Publié : 11/11/2023 6:32 pm
MrSyNRG
(@mrsynrg)
I am having the same issue as well. I was able to read the current pid values with the m301 command but when trying the m303 it returns unknown command. Anybody have any idea how to fix this?
Publié : 26/11/2023 3:44 am
imurfathersimba
(@imurfathersimba)
It seems like this does not work anymore with the new 5.1.0 firmware upgrade. Any idea on how to get this working?
Publié : 26/11/2023 10:38 pm
MrSyNRG
(@mrsynrg)
After some digging i guess that the mini doesn't allow this command after all, and doesn't need it as it's running some custom algorithm that should be fine among all hotends/conditions etc so a pid tune isn't necessary
Publié : 26/11/2023 10:43 pm
imurfathersimba
(@imurfathersimba)
The thing is, I was able to do it about a year ago. I keep getting errors when trying to heat my hotend to 270 for a cold pull. I looked around and it said that it might be because the pid tuning is off, which makes sense since I have a slice engineering copperhead. I should create a separate post for error.
Ce message a été modifié il y a 2 years par imurfathersimba
Publié : 27/11/2023 12:51 am
PHabermehl
(@phabermehl)
Just uncomment the according line in "include/marlin/Configuration_MINI_adv.h"
 * Enable PID autotune
#define PID_AUTOTUNE
and M303 will work again.
But beware, if the behaviour of your hotend is different from the Prusa, you might have to touch the hotend monitoring, too.
Changing hardware means: if the software still works, the hardware makes no difference, and if the hardware makes a difference, you have to adapt the software.
Of course you might run into a memory shortage. The Mini has a rather small EPROM so this might be the reason why some unneeded code was removed.
Finally, I would recommend to apply the PID tuning values to the firmware so you don't have to use M301 in your GCode and can print universal code without altering.
Good luck
Peter
Publié : 07/12/2023 1:11 pm
imurfathersimba
(@imurfathersimba)
Thank you for the information. I will test my printer with the new hardware I got (my thermistor and heater wires broke) without making any PID changes and see if it still works before messing around too much with the software.
Publié : 07/12/2023 3:48 pm
Rat_Patrol
(@rat_patrol)
I'm having an issue where a revo with 0.6 ObXidian is giving thermal runaway errors. I tried a PID tune since I plan on running this nozzle a lot (and would just tune for the 0.4 brass and have the proper PID values in the start gcode for that profile), but I'm having the same "unknown command" issue.
I'm understanding it is due to the input shaper FW. Is there a workaround other than compiling your own FW?
Publié : 11/12/2023 5:36 pm
bmorgenthaler
(@bmorgenthaler)
So M303 isn't available but M301 still is, a possibility is to revert to older firmware, run the PID tune there and get the numbers, then upgrade your firmware and put the new numbers in your gcode.  Though I don't know if any of the logic for the PID calcs hav changed in the newest FW with InputShaping.
Posted by: @rat_patrol
MINI+ with FW:4.3.3, Bondtech IFS Extruder, drilled out PC4-M8 couplers, 1 piece Capricorn bowden.
Publié : 11/12/2023 5:54 pm
PHabermehl
(@phabermehl)
The PID controller structure was massively changed so it doesn't make sense.
I've reverted (most of) the changes and re-enabled M303 in the SW. So I'd say there's no way around building a custom SW.
Posted by: @bmorgenthaler
Publié : 11/12/2023 7:20 pm
