Prusa MINI not turning on
JJ
 JJ
(@jj-4)
My MINI suddenly stopped turning on today. I had just run the Octoprint bed level visualizer and noticed a few minutes later the printer was powered off. When I reset or power cycle, the fans spin up for 1-2 seconds then shut off.
I've changed outlets, reseated the power cords at the printer and power brick, and confirmed the power outlets are good. I also opened up the case and snugged up all the connections in case something had come loose.
Any ideas for further troubleshooting while I wait for a response from Prusa?
Opublikowany : 21/05/2020 7:44 pm
RE: Prusa MINI not turning on
Posted by: @jl
I would contact the Prusa chat. Login with your Prusa account, select eshop. After some seconds there shoukld appear the chat window. The answer to an email from Prusa can take a week. In the meantime you could check the PU with a multimeter. There should be a stable voltage of 24v or a little more.
Opublikowany : 21/05/2020 9:35 pm
1 ludzie polubili
JJ
 JJ
(@jj-4)
thanks karl-herbert for pointing out the chat capability. My browser plug-ins were blocking that popup so I swapped browsers and got it. Huge thanks to Prusa Support for helping me identify the problem.
The printer was indeed turned on, it was just the display that was disconnected. Realized the board was running two ways: 1) small green LED on the Buddy board, 2) printer recognized in Windows Device Manager, which led me to the ribbon cable.
Problem: Loose ribbon cable connection at the display
Troubleshooting steps:
- Inspect power supply pins (PSU, cables, and Buddy board)
- Snug up all the connections in the box
- Plugged printer into my computer via microUSB cable and turned the printer on. Checked Device Manager to see whether the printer was recognized
- Inspected the entire length of the ribbon cable, which led me to the loose connection at the display.
Opublikowany : 21/05/2020 11:01 pm
