Prusa Link Local Login Credentials
Georg
(@georg-2)
Hello. Since firmware 5.1.0 something has changed with the prusa link local login. Before there was a key to enter the webpage, now there needs to enter a username and a password. Where can i set this credentials?
Publié : 28/10/2023 6:33 pm
RE: Prusa Link Local Login Credentials
Not sitting in front of a Mini right now but it should be in the Network section of the LCD menu under Prusa Link.
Publié : 29/10/2023 11:18 am
2 personnes ont aimé
Georg
(@georg-2)
Thank you! I will have a look at this section in the printers menu, when the current print has finished. 🙂
Publié : 29/10/2023 12:06 pm
Georg
(@georg-2)
Hmmm…got the user name. Password is the same, but credentials do not wirk for prusa link.
I downloaded the prusa_printer_settigs.ini. There i can see that the credentials are empty. I am going to fix this, but i guess this is a known bug.
[service::local]
enable = 1
username =
password =
api_key =
Publié : 29/10/2023 1:55 pm
Georg
(@georg-2)
Modify this file does not help. Can not get logged in to the Prusa Link Webinterface.
Additional i have to say, that my Mini is connect using LAN cable. Wifi is not used on the printer.
Publié : 29/10/2023 2:08 pm
Jlev
 Jlev
(@jlev)
I have the same issue. Can't use prusalink after the upgrade to 5.1 as the login credentials are not accepted.
Publié : 02/12/2023 11:09 am
mixer3d
(@mixer3d)
you have to add api key which is visible in the settings of the network configuration, if you have also login window where you have to write some username, i think "maker" is default one...
Publié : 09/12/2023 1:19 am
Jlev
 Jlev
(@jlev)
Yes, that is the issue. When typing in "maker" and the corresponding password found in the prusalink menu on the Mini+ it is NOT accepted, thus I can't get prusalink to work after the upgrade. Previously I could login by typing in the API key.
Publié : 16/12/2023 2:02 pm
ArnoldG
(@arnoldg)
Membre
Well I have this printer for a log time and started with no web page and then with the api key.
but more then view is all you can do.
So last time I tried again and also got an user name password question.
Now for those like me searching for the answer..
user = maker
password = apikey.
that works for me.
Publié : 27/01/2025 5:04 pm
1 personnes ont aimé
