Post-crash checks, maintenance
alice_nerd
(@alice_nerd)
Due to a g-code experiment gone awry, I drove the print head straight down into a solid infill part, deflecting the corner of the bed down a good 4-5mm or so before I hit reset. I didn't hear any breaking noises, I backed the Z axis off as soon as it finished rebooting, and it seemed to bounce back ok. I recalibrated the z axis and I have a (safe, non-experimental) print running now and it seems to be going alright, so nothing's obviously broken. But are there any procedures I should follow after a major crash like that? Things I should disassemble, subtler damage or misalignments I should check for? Is the fact that I had to recalibrate an indicator of larger problems?
Also, is there just no crash detection on the Mini+? I figured with the Trinamic drivers (and the fact that sensorless homing uses the same current-sense circuits) it would at least be able to detect something drastic like this.
Thanks!
Publié : 13/11/2021 9:05 am
RazzerMatazzer
(@razzermatazzer)
RE: Post-crash checks, maintenance
I would check the heat bed. By removing the steel sheet you can have a peek, and make sure everything is levelled. If the heat bed is damaged, call up Prusa Support. I would also see if that corner properly heats by preheating to a safe temperature and tenderly touching it, see if it heated evenly.
Publié : 24/11/2021 9:50 pm
