PLA stuck to the hotend
Zeelily Clockwerks
(@zeelily-clockwerks)
Help. I let a print go on overnight. In the morning I saw that the print had failed. Goobs  of PLA were stuck to the bottom and right side of the hot end. I was able to raise the temp and take off the PLA on the bottom, but the stuff on the side still remains.  Any suggestions?
Postato : 28/09/2020 7:21 pm
Utenti
RE: PLA stuck to the hotend
I use a nylon toothbrush to remove it.  Heat and remove.
Postato : 28/09/2020 7:23 pm
Zeelily Clockwerks
How hot?
Postato : 28/09/2020 7:54 pm
jsw
 jsw
(@jsw)
I would heat it to 250 or so, let it sit and get good and warm, and you should be able to brush it off.
Postato : 28/09/2020 8:11 pm
Zeelily Clockwerks
Thank you.
Postato : 28/09/2020 8:23 pm
Posted by: @rocknrude
i would then also search for the cause (overextrusion, bad LA values, extruder calibration...).
Postato : 28/09/2020 8:47 pm
