PLA stuck to the hotend
Help. I let a print go on overnight. In the morning I saw that the print had failed. Goobs of PLA were stuck to the bottom and right side of the hot end. I was able to raise the temp and take off the PLA on the bottom, but the stuff on the side still remains. Any suggestions?
RE: PLA stuck to the hotend
I use a nylon toothbrush to remove it. Heat and remove.
How hot?
I would heat it to 250 or so, let it sit and get good and warm, and you should be able to brush it off.
Thank you.
i would then also search for the cause (overextrusion, bad LA values, extruder calibration...).
