New Hotend Mini+ - Mesh bed leveling 3rd point was pressing hard into the heatbed, bending it.
Hello guys,
I exchanged my MINI Hotend today, as per Manual. Connected everything, did the Selftest - all good.
Axes are not visibly misaligned, I put the nozzle to height 1 and moved manually around. Seems to be at the same height everywhere.
Then I did a mesh bed leveling to see if all points are good to go.
He did the first 2 points perfectly BUT THEN, it pressed full power into the 3rd point, bending the heatbed visibly and hearing the motor trying to rotate forcefully and hard into the heatbed!! What the heck.
I only dismounted and mounted, connected and disconnected the hotend, I did not touch the axes, the sensor, nothing. The hotend height is flush like it should be.
Help.
Respondido : 11/01/2024 1:55 pm
