My Prusa mini won't load filament
meloncella
(@meloncella)
on my new Prusa mini, which I love, I had already noticed that loading the filament never worked on first try but only after a couple of times.
Now I tried to load new filament and it cannot load it in any way, I tried many times, the gear turns but it cannot grab it and the filament gets stuck (it also broke now so I guess I have to disassemble to pull it out...).
I do the sharp cut at the end of the filament and follow all instructions but still not pulling it properly, I use prusament.
Please advice on how to fix it, I guess I have to open it up?
Thanks,
Carlo
Publié : 01/10/2020 10:20 am
Membre
RE: My Prusa mini won't load filament
I have had to clean out the extruder a number of times.
Check:
https://help.prusa3d.com/en/guide/how-to-access-and-clean-the-extruder-pulley-mini_126457
Publié : 01/10/2020 11:18 am
Posted by: @meloncella
Thanks,
Carlo
When pretensioning the spring you have to experiment a bit, that takes some practice. The screws of the extruder should also not be overtightened.
Good success!
Publié : 01/10/2020 1:01 pm
Ladik406
(@ladik406)
RE: Můj Prusa mini nenačte vlákna
@charles-h13
Moc moc děkuji. Thank you very much
Publié : 01/10/2020 1:59 pm
Ladik406
(@ladik406)
Problém vyřešen. filament se zdeformoval v průhledné hadičce po trysku a musel jsem jej vytáhnout silou kleštěmi. vše ok a už jede. Děkuji za pomoc.
Publié : 01/10/2020 2:48 pm
meloncella
(@meloncella)
Ok thanks for all the replies! I'll try this weekend and let you guys know
Publié : 01/10/2020 4:39 pm
