Mini reboots after a short while
NNHDesign
(@nnhdesign)
Hello guys and girls
I'm having problems with my mini it reboots after a short while have tried different files with the same result 🙁 it doesn't come with a fault message just reboots anyone had that problem before..?
This topic was modified 4 years temu by NNHDesign
Opublikowany : 04/04/2022 7:45 am
K7ZPJ
(@k7zpj)
RE: Mini reboots after a short while
  • Re-seat both ends of the power cord that goes from the wall plug to the power brick.
  • Unplug the power cord that goes from the power brick to the mini and plug it back it.
  • If that doesn't resolve the problem then contact support via chat in the e-shop
Opublikowany : 05/04/2022 9:22 pm
mark
 mark
(@mark)
Mine rebooted and came back up with a watchdog reset on every self test and the chat suggested I reformatted the USB stick. That fixed it.
Regards,
Mark
Opublikowany : 06/04/2022 3:41 am
EinTiroler
(@eintiroler)
My Mini recently started crashing even without a USB stick. When I try to change the filament (in the menu) then it crashes immediately. Have already tested different firmware versions and all cables sit tight.
Opublikowany : 06/04/2022 9:32 pm
