Live adjust Z for .25mm nozzle
bill2009
(@bill2009)
I normally print with a .4 mm nozzle and my Z adjustment is at -1.523. I switched in an .25 and I know I have to move it lower but even at the limit of -2 it seems too high. The filament is clearly dropping freely from the nozzle. Not getting squished at all.. What am I doing wrong? Octoprint is running by the way.
thanks for any help
Best Answer by Walter Layher:
Did you check the distance of your Pinda probe to the print sheet? Perhaps it is too high and beyond the usable limit.
Respondido : 01/05/2023 8:35 pm
Walter Layher
(@walter-layher)
RE: Live adjust Z for .25mm nozzle
Respondido : 01/05/2023 8:58 pm
bill2009
(@bill2009)
no! I'll check it - maybe i bumped it changing the nozzle.
Thanks.
Respondido : 01/05/2023 11:14 pm
René
(@rene-3)
And don't forget to select the 0.25mm printer profile in the Prusa slicer when slicing an object.
Respondido : 02/05/2023 7:37 am
1 les gusta
bill2009
(@bill2009)
Re-setting the z probe height fixed it - thanks again.  I still have to set the z level to -1.9 but at least it's in the range now.
Respondido : 02/05/2023 10:16 pm
