[Resuelto] How to get the brass olive onto PTFE tube?
Antimaterie
(@antimaterie)
my brass olive on the ptfe tube after the extruder come loose and I can't put it back in place. Any hint how to do this?
thx in advance!
Respondido : 23/11/2021 8:27 pm
BogdanH
(@bogdanh)
RE: How to get the brass olive onto PTFE tube?
Not sure if I understand.. but olive should be slightly loose, so it can travel along PTFE -it's position becomes fixed when you tighten the fitting.
[Mini+] [MK3S+BEAR]
Respondido : 23/11/2021 8:44 pm
jkavalik
(@jkavalik)
Miembro
The thin edges can get compressed when tightened - I was able to widen it enough using a screwdriver with conical head and rotating it inside.
Respondido : 23/11/2021 8:49 pm
Antimaterie
(@antimaterie)
Initialy I didn't know how this brass olives work. (I got the preassembled version) Now I know 😉
Posted by: @jkavalik
Thanks for that tip! I used a Torx bit Size 10 to widen the used olive. I was able to refit the olive. Sadly it didn't hold  the pressure when feeding filament. The tube looks a bit used at the end too.
More or less by accident I will get a capricorn tube and a pc4-m8 in the next days. Is it worth to use that or should I order one from prusa? (takes longer and need to pay shipping costs)
Respondido : 23/11/2021 11:08 pm
BogdanH
(@bogdanh)
With new Mini, you also got two spare olive.
[Mini+] [MK3S+BEAR]
Respondido : 24/11/2021 8:39 am
Antimaterie
(@antimaterie)
Ah yes, I forgot the box with the mini spare parts. But I found the reason for the loose Oliven.
I had extrusion problems, so I disassembled the hotend. I didn't do this for the first time, but I still feel being a hotend dis/assemble noob. Sadly this time the heartbreak was not correct screwed in and plastic leak onto the heat block. Not much, but enough to fuse heat break and block.
Now I have more problems then a loose olive.... Good chance to get more hotend maintenance practice.
Respondido : 24/11/2021 8:53 am
