Heatbed electrical connection
adynis
(@adynis)
I've seen a facebook post from Chris Warkocki with a very strange issue: The 2 high-power cables connecting to the heatbed look like are connected on the other side of the PCB, where there are no copper pads, while the copper pads are only touching the screws ....
Question:
Is this the same in all MINIs ?
I'm puting here some pictures from Chris' post ( https://www.facebook.com/groups/prusacommunity/permalink/1227584010915662/ )
This topic was modified 6 years temu 5 times by adynis
Opublikowany : 19/02/2020 12:49 am
adynis
(@adynis)
RE: Heatbed electrical connection
[ And ... I succeeded to add images as thumbnails ... 👍  ]
This post was modified 6 years temu 2 times by adynis
Opublikowany : 19/02/2020 12:57 am
Crawlerin
(@crawlerin)
IIRC MK3S build manual emphasizes to put screws and cables on the correct side and make cable ends touch the pad. This does not look assembled correctly then. Is it dangerous or not?
This thread with x-ray pics show it mounted under as well. https://forum.prusa3d.com/forum/hardware-firmware-and-software-help/pictures-say-more-than-a-thousand-words/ I will check mine tomorrow.
Opublikowany : 19/02/2020 2:05 am
adynis
(@adynis)
I will not make a summary of the Facebook discussion, but this screenshot seems important 🙂
Opublikowany : 20/02/2020 12:32 am
4 ludzie polubili
Matteo Cristini
(@matteo-cristini)
@adynis
Thanks for the screenshot. I'm sure it's gonna work fine, but it still feels like the wrong way of doing it...
Might be the first mod to design!
Opublikowany : 20/02/2020 6:24 pm
Crawlerin
(@crawlerin)
@matteo-cristini
https://www.prusaprinters.org/prints/22527-mk3-style-heatbed-cover-prusa-mini
He took existing MINI cover to keep the height and re-designed it to be MK3 style cover.
Opublikowany : 20/02/2020 6:31 pm
2 ludzie polubili
Crawlerin
(@crawlerin)
https://help.prusa3d.com/en/article/heatbed-connection-resistance-analysis-mini_114422
This post was modified 6 years temu by Crawlerin
Opublikowany : 21/02/2020 11:00 am
1 ludzie polubili
Matteo Cristini
(@matteo-cristini)
@crawlerin
Thanks for the links!
Opublikowany : 21/02/2020 11:07 am
