Heatbed electrical connection
adynis
(@adynis)
I've seen a facebook post from Chris Warkocki with a very strange issue: The 2 high-power cables connecting to the heatbed look like are connected on the other side of the PCB, where there are no copper pads, while the copper pads are only touching the screws ....
Question:
Is this the same in all MINIs ?
I'm puting here some pictures from Chris' post ( https://www.facebook.com/groups/prusacommunity/permalink/1227584010915662/ )
Questa discussione è stata modificata 6 years fa 5 tempo da adynis
Postato : 19/02/2020 12:49 am
adynis
(@adynis)
RE: Heatbed electrical connection
[ And ... I succeeded to add images as thumbnails ... 👍  ]
Questo post è stato modificato 6 years fa 2 tempo da adynis
Postato : 19/02/2020 12:57 am
Crawlerin
(@crawlerin)
IIRC MK3S build manual emphasizes to put screws and cables on the correct side and make cable ends touch the pad. This does not look assembled correctly then. Is it dangerous or not?
This thread with x-ray pics show it mounted under as well. https://forum.prusa3d.com/forum/hardware-firmware-and-software-help/pictures-say-more-than-a-thousand-words/ I will check mine tomorrow.
Postato : 19/02/2020 2:05 am
adynis
(@adynis)
I will not make a summary of the Facebook discussion, but this screenshot seems important 🙂
Postato : 20/02/2020 12:32 am
4 persone hanno apprezzato
Matteo Cristini
(@matteo-cristini)
@adynis
Thanks for the screenshot. I'm sure it's gonna work fine, but it still feels like the wrong way of doing it...
Might be the first mod to design!
Postato : 20/02/2020 6:24 pm
Crawlerin
(@crawlerin)
@matteo-cristini
https://www.prusaprinters.org/prints/22527-mk3-style-heatbed-cover-prusa-mini
He took existing MINI cover to keep the height and re-designed it to be MK3 style cover.
Postato : 20/02/2020 6:31 pm
2 persone hanno apprezzato
Crawlerin
(@crawlerin)
https://help.prusa3d.com/en/article/heatbed-connection-resistance-analysis-mini_114422
Questo post è stato modificato 6 years fa da Crawlerin
Postato : 21/02/2020 11:00 am
1 persone hanno apprezzato
Matteo Cristini
(@matteo-cristini)
@crawlerin
Thanks for the links!
Postato : 21/02/2020 11:07 am
