Having trouble with print quality (under-extrusion) after printing with relatively no problem for a year or so.
[Rozwiązany] Having trouble with print quality (under-extrusion) after printing with relatively no problem for a year or so.
Strona 5 / 9
harmlessVI
(@harmlessvi)
Yeah I used some a few months ago but it was in kinda bad conditions so I figured it was no good, and it printed terrible, much like this time.
I used some when I first got it and it was ok but it had a lot of inconsistency, sometimes it bubbled sometimes under extruded.
Now that I think about it, never had a really quality print with Hatchbox, which is weird because I've seen Prusas use it just fine before.
I will have to try the oven trick.
I will give the calibration one more shot with the Hatchbox.
Opublikowany : 03/01/2023 1:40 am
Hello
(@hello)
RE: Having trouble with print quality (under-extrusion) after printing with relatively no problem for a year or so.
yeah try the oven trick i use esun pla+ i find that stuff really good
Opublikowany : 03/01/2023 1:42 am
Hello
(@hello)
glad that your printer is up and running and after 4 pages we came down to a soulution
harmlessVI
(@harmlessvi)
cool I will have to look into that. Should I try the oven trick before doing another first layer? Currently running the cube test print.
Opublikowany : 03/01/2023 1:43 am
harmlessVI
(@harmlessvi)
honestly lol
was a great learning experience though, a ton of new troubleshooting steps that I had never done so at least there was some learning.
Hello
(@hello)
do the oven trick first 5 miniuits no less no more then do first layer and let me know how it goes yes sorry if some of it seemed confuising
Opublikowany : 03/01/2023 1:48 am
harmlessVI
(@harmlessvi)
Will do. No problem, I appreciate the help.
Opublikowany : 03/01/2023 1:50 am
Hello
(@hello)
all good the if the oven trick dosent work then heat printer to 260 degress run the fillament through a bit then col down printer to 220 and try print
Opublikowany : 03/01/2023 1:52 am
harmlessVI
(@harmlessvi)
ok, also is that oven trick in Celsius (80c)
Opublikowany : 03/01/2023 1:55 am
Hello
(@hello)
yes
Opublikowany : 03/01/2023 1:56 am
harmlessVI
(@harmlessvi)
American oven moment lol
Hello
(@hello)
hahaha lol
Opublikowany : 03/01/2023 1:57 am
Hello
(@hello)
don leve it in too long only enough to draw out the humity
Opublikowany : 03/01/2023 2:03 am
harmlessVI polubić
harmlessVI
(@harmlessvi)
Yeah I ran it through the oven, ill test in a minute when the box is finished.
Opublikowany : 03/01/2023 2:05 am
Hello
(@hello)
Opublikowany : 03/01/2023 2:08 am
harmlessVI
(@harmlessvi)
Sides/bottom are good, top is a little funky not entirely sure why
Opublikowany : 03/01/2023 2:14 am
Hello
(@hello)
that is not right
Opublikowany : 03/01/2023 2:16 am
Hello
(@hello)
what was your tmp at
Opublikowany : 03/01/2023 2:17 am
harmlessVI
(@harmlessvi)
215c
could try running it at 220c
Opublikowany : 03/01/2023 2:18 am
Hello
(@hello)
i mean temperature
Strona 5 / 9
