Having trouble with print quality (under-extrusion) after printing with relatively no problem for a year or so.
[Rozwiązany] Having trouble with print quality (under-extrusion) after printing with relatively no problem for a year or so.
Strona 4 / 9
Hello
(@hello)
RE: Having trouble with print quality (under-extrusion) after printing with relatively no problem for a year or so.
i think maybe the fillament could be damp
Opublikowany : 03/01/2023 12:42 am
harmlessVI
(@harmlessvi)
Filament is brand new, has only been out of package for like a few days, conditions are generally decent where I have it too, so I wouldn't expect it to have any significant moisture issues.
Opublikowany : 03/01/2023 12:44 am
harmlessVI
(@harmlessvi)
If this first layer cal doesn't work I will try switching to some prusament that I have
Hello
(@hello)
yeah might be best once fillament changed over do first layer cal again please
Opublikowany : 03/01/2023 12:45 am
harmlessVI
(@harmlessvi)
Not great but that is what it did not changing anything, currently set to 0.930. Going to check with prusament here in a minute.
Opublikowany : 03/01/2023 12:53 am
Hello
(@hello)
try lowering the z height
Opublikowany : 03/01/2023 12:55 am
harmlessVI
(@harmlessvi)
Alright I will lower it a bit, currently attempting with some Prusa PLA.
Opublikowany : 03/01/2023 12:58 am
Hello
(@hello)
ok
Opublikowany : 03/01/2023 1:00 am
harmlessVI
(@harmlessvi)
Turned out quite nice from what I can tell with the Prusa PLA, I'm going to give that test file another shot.
Opublikowany : 03/01/2023 1:08 am
Hello
(@hello)
yes that is a verry good first layer
Opublikowany : 03/01/2023 1:09 am
1 ludzie polubili
Hello
(@hello)
hows it going
Opublikowany : 03/01/2023 1:21 am
harmlessVI
(@harmlessvi)
Did really well till the last couple layers, still had some stringing. Left for a minute so didn't actually see it fail at the top there but the print was sitting at 100% like that. Still at 215c
Opublikowany : 03/01/2023 1:22 am
Hello
(@hello)
yes the tubes look fine it is ok for it to slip on bed will do on all printers and the brim has printed prfectly so i would say that your printer is running perfectly
Opublikowany : 03/01/2023 1:25 am
Hello
(@hello)
what do you think ?
harmlessVI
(@harmlessvi)
Yeah that's about what I had before as far as print quality goes in general. I would agree that it's running pretty good.
Must have just been bad/damp filament. Very weird considering I just got it. Any thoughts on that?
Opublikowany : 03/01/2023 1:30 am
Hello
(@hello)
it can happen what make is it
Opublikowany : 03/01/2023 1:31 am
Hello
(@hello)
put it in an oven for 5 min 80 degress thats what i do
Opublikowany : 03/01/2023 1:32 am
1 ludzie polubili
harmlessVI
(@harmlessvi)
Hatchbox PLA
Opublikowany : 03/01/2023 1:35 am
Hello
(@hello)
hatch box unusal for that to be damp have you ever used hatch box before
Opublikowany : 03/01/2023 1:36 am
Hello
(@hello)
try do first layer cal with hatch box fillament again just to see
Opublikowany : 03/01/2023 1:39 am
1 ludzie polubili
Strona 4 / 9
