RE: Having trouble with print quality (under-extrusion) after printing with relatively no problem for a year or so.
print please (2) please print this
yeah the temperatures were at 215c nozzle and 60c bed
ok I will give that a shot once this first layer is done
couple of things that it could be and its gona be trial and error please print print please (2)
ok also send me photo of first layer then we can see how to make hatch box fillament work aswell
ok well focus on getting that top layer ok then we can come back to this hatch box fillament if thats ok with you
yep that works for me
do you have that print going now
it should be a circle
strange it all looks good correct
yeah looks great.
should I run another box? It's possible somethings different with the gcode for Prusa PLA vs Hatchbox
try print this please print please
ok
shouldent be the only thing that changes is temp basicly
ok well I will give this square a print and see what happens
if this works then i wouldent worry about the bad print
Unfortunately it did not work
While printing it began making a noticeable clicking around the extruder adjustment screw, upon inspection, it appears the printer itself tightened the screw back to the position I showed in my original images which is really weird.
strange
