GCODE z offset for different points on bed?
Hi
My first layer is generally fine apart from the left side of the bed ( 1 and a half squares in) where the nozzle is too close. I always need to babysit the first layer and so was wondering if I could set a different z offset for that part of the bed on the mini using gcode?
I had a Mk2 a while back and remember doing something similar so was wondering if I could do something similar as mesh bed leveling doesn't seem to be compensating enough.
If this isn't the right way to go about this then open to other suggestions.
Tom
Opublikowany : 04/05/2020 7:46 pm
